Minneapolis Moline Tractors Discussion Forum
ser no
sam in mo
01-07-2004 11:42:26
Found a MM in the woods has no tires or wheels front or rear. Trycicle front end It is rusty for the most part. The only number that I found on it was on the side of the motor.It was in the 75000 on up. Where is the Model No located at? Can you tell by the motor No what year and model No it is ? Any help would be most helpfull. Thanks Sam
Jim Parisot
01-07-2004 16:09:55
 Re: ser no in reply to sam in mo, 01-07-2004 11:42:26
sam in mo,
That could be the engine serial number of a 1947 RE engine, which was used in the Z series of tractors. The tractor serial number will be on a tag on the right side of the transmission housing, and will indicate the model number. Give us everything on the engine tag if you can't find the model number on the tractor tag. You can also give us some casting numbers off major parts. With a little more info we can narrow down what you have. Hope this helps.
Jim
