Minneapolis Moline Tractors Discussion Forum
MM Z Hyd cyl?
Ted
01-05-2004 20:58:23
My Z 1952? hyd. cyl. drops after 8 to 10 minutes. It is connected to an after market/homemade style 3pt. Is it normal for it to drop? I recently changed trans fluid recently, so I know it has enough fluid.
Kelvin
01-06-2004 17:18:38
 Re: MM Z Hyd cyl? in reply to Ted, 01-05-2004 20:58:23
I don't see what transmission fluid has to do with it. The hydraulic system and the transmission are separate systems on a '52 Z.
What I would suggest is to take the 1-1/4" plug off the right side of the hydraulic reservoir under the gas tank and check the level. It should be up to the hole.
If that is O.K., problem could be the cylinder O-ring, or it could be the check valve in the hump on the side of the cylinder.
Is this unloaded, or do you have something on the 3-point?
Ted
01-06-2004 19:59:01
 Re: Re: MM Z Hyd cyl? in reply to Kelvin, 01-06-2004 17:18:38
Was just going by what my son said. I picked up a IT manual today will study it further. Thank you for setting us straight on this system.
Duane
01-07-2004 04:47:59
 Re: Re: Re: MM Z Hyd cyl? in reply to Ted, 01-06-2004 19:59:01
Is it a MM cyl. If it is rebuild the cyl if not get a MM Cyl.
