Minneapolis Moline Tractors Discussion Forum
BF shifter problems
Tim G
01-04-2004 12:52:26
Hi,
I have my BF torn down to just about nothing. I have a problem with the shift rod. Has anyone ever had their BF tranny open? I can not figure out how the shift rod is supposed to stay in the fork mechanism. There are three different forks and my shift rod with slip between the forks, I then have to try to get it back it the fork slot to change gears. I am pretty sure the rod should not come out of the shifter slots inside the tranny but can not figure out how it is supposed to stay.
Any Ideas?
Thanks,
Tim G
Tucson
Kelvin
01-04-2004 17:52:23
 Re: BF shifter problems in reply to Tim G, 01-04-2004 12:52:26
never had a BF open, but most I've seen had a spring of some kind to hold the ball part of the shift lever in a ball shaped socket.
Keith Ault
01-04-2004 17:59:30
 Re: Re: BF shifter problems in reply to Kelvin, 01-04-2004 17:52:23
had same problem,Cockshutt 20 uses same transmission.Phil Heisey 215-256-8651 sells a kit,includes socket for ball of shifter to set it,pin for rod,needed washers and a much easier snap ring,cured my problem.I need a seat pan for a B F thanks Keith Ault
Kelvin
01-05-2004 17:12:20
 Re: Re: Re: BF shifter problems in reply to Keith Ault, 01-04-2004 17:59:30
Don't have a seat pan, but I can tell you that the crimp type edge on mom's BG seat is a dead ringer for the seat on our Farmall cub.
