Minneapolis Moline Tractors Discussion Forum
Brake cables for u or z
mndigger
01-03-2004 04:10:28
Looking for brake cables for u or z mm part # jt9101 these cables are no longer available from agco.I've tried welters no luck there. Is there someone out there who can repair these that you may know of. Thanks in advance for any help.
Mark H.
01-03-2004 08:23:59
 Re: Brake cables for u or z in reply to mndigger, 01-03-2004 04:10:28
mndigger. Try Wilbert Kerchner (815) 539-6965 in IL. In Nov. I bought two cables for my 1951 Za
If he doesn't have no one will he's the MM god
Good luck Mark H.
Kevin Moschenrose
01-03-2004 12:56:29
 Re: Re: Brake cables for u or z in reply to Mark H., 01-03-2004 08:23:59
Some one posted here I think or on tony's site posted that they can repair old ones to as good as new or make them not sure which. You may want to go to the archives part of this web site and do some checking around. They where from down in the Carolina's someplace I thought like that.
Kelvin
01-03-2004 17:03:07
 Re: Re: Re: Brake cables for u or z in reply to Kevin Moschenrose, 01-03-2004 12:56:29
I made that post: At one time (mid '90s) David Paul in Pickens SC could repair those brake cables. Actually, I think he used your old sheath, spring, clevis, and threaded adjuster, and just replaced the cable.
Since that time, I have lost touch with him. The last contact I had was a calendar with a note that he was owner/manager of Affordable Equipment in Easely South Carolina. That was in '97 or '98.
Kevin Moschenrose
01-03-2004 21:21:24
 Re: Re: Re: Re: Brake cables for u or z in reply to Kelvin, 01-03-2004 17:03:07
Kelvin, I knew I read it somewhere just couldn't remember where it was! Darn Moline addiction or is it with draws? Humm not sure on that either??
