Minneapolis Moline Tractors Discussion Forum
Jetstar 2 3 point hitch
Larry
01-02-2004 20:16:06
Anyone out ther have all the parts to add a 3point to a Jetstar 2 Moline. Will a hitch from a 335 445 or 4 Star or any other model fit and work?
SWMolines
01-03-2004 01:43:46
 Re: Jetstar 2 3 point hitch in reply to Larry, 01-02-2004 20:16:06
Be careful here. The JetStar 2 is the first MM of this size with externally plumbed hydraulics. The MM 445 used an earlier system that was internally plumber. Systems from a 445 will not simply bolt on and work on a JetStar 2.
The 3 point off of a 4 Star, late M5, 602 or early 670 are all externally plumbed and should work much easier than a 445 system.
Kevin Moschenrose
01-02-2004 21:36:56
The parts from a 445 and 4-star will work on it. The 445 was replaced by the Jetstars and when MM came up with a newer replacement they just rolled their newer tractors over to use up parts and not have to make as many new ones or design changes when they had a model change.
