Minneapolis Moline Tractors Discussion Forum
diesel mechanics help
gary
12-30-2003 05:42:05
not sure if this is a good place to ask this, but here it goes. i have a roosamaster diesel pump on a pickup that pumps very little fuel. the engine will not run. i installed an electric fuel pump and am getting fuel (a good supply) to the pump, but very very little coming out. does anyone know of a good website that shows the break down of these pumps, or have any advice?? thanks.
gary
01-05-2004 06:28:46
 Re: diesel mechanics help in reply to gary, 12-30-2003 05:42:05
Hi guys, thanks for all the ideas. i took the pump off and tore it down. cant say that i see anything as being a problem. nothing stuck, nothing wore out, but i did see some stress cracks in the case. prescreen was clean, all bores were clean, transfer pump looked good, seals looked good, it's confusing. since i went to the local tech college for diesel tech one would think i should know this, but that was 20 yrs ago and it's been 10 since i had a pump apart, but i am going to go back to the college and use the test stands and see what happens. thanks again for all the suggestions, i will check some of the items again just to be sure.
Runner, Al.
12-31-2003 20:21:36
Check the return line. If it is stopped up, it will not run. Good Luck David
Bob
12-31-2003 16:50:48
Has the unit been sitting unused for a while?
If so, often the pump pistons get stuck in their bores and don't move outward to take on fuel, so no injection occurs. It is a relatively simple matter to take the pump apart, and free them, and about a $30.00 seal kit to put it back together. It's the $300.00 to $400.00 labor at the pump shop that really hurts!
Do you have any fuel delivery to the injectors, or is the fuel flow you're referring to coming out the return fitting at the top? Is your electric shut-down solenoid working?
galenv
12-31-2003 14:50:57
Don't know how mechanical you are but roosa or any fuel pump can be a pain need special tools to install seals and such, that said. You can have several problems plugged screen oninlet, stuck metering valve(canusually start just won't gain rpms) plugged fuel return can be problem usually runs a while then dies, veins on transfer pump worn not pumping into main pump makes them real tuu to start. The list can go on I suggest you pull the pump and have it redone depending onmiles and age it's just a matter off time anyway
george md
12-30-2003 15:40:23
Gary,
Sounds like the housing pressure regulator
is plugged up. It is the black fitting in the return
line that is screwed into the pump housing. remove
it and look thru it at a bright lite, see if there
are any shadows around the opaque glass ball . If
there are it is plugged and that means the governor
drive ring is failing and it needs a kit .
george
Larry from MD
12-30-2003 14:09:28
There is a safty screen in the pump,its right below where the fuel goes in.You can remove the plug on the bottem and see if fuel or crud comes out.The screen and the fitting is very thin and its easy to break it.If you clean it try to suck out the stuff throught the hole where the fitting is.If you lift the screen the crud goes in to the pump.If fuel still wont go in the pump, most likly you need to take it to a pump repair place.
