Minneapolis Moline Tractors Discussion Forum
External lube pump A4t-1600, G1350
Rick K
12-23-2003 18:02:08
Have a 585 running 40 psi at high and low idle, hot or cold. Manual says 50-55 psi. Is there a problem and and is there a way to adjust pressure?
Engine doesn't use oil. Also does anyone sell
replacement tachometers for MM's?
Larry from MD
12-24-2003 14:17:02
 Re: External lube pump A4t-1600, G1350 in reply to Rick K, 12-23-2003 18:02:08
If you have the external pump there is a relief valve right on the pump it can be shimmed up if you want.Mine runs 60 to 62 fast and 40 to 45 slow.Years ago the dealer told me it should be 70 all the time.I did get that with new bearings and cold oil.I don't think you would have a problem at 40psi.The big problem is if the relief sticks open, the pump looses its prime when the engine is stopped.Next time its started the bearings burn up.I think its best to instal a check valve so this cann't happen when the valve sticks.You have been warned.
