Minneapolis Moline Tractors Discussion Forum
ZAE - Hydraulic to be removed
Rick
12-22-2003 07:11:21
I just got a 1950 ZAE and it has a hydraulic front loader on it. I want to remove this, everything works good on it, but there are 2 pressure lines that go into a pump on the left front of the engine. What should go there in placement of the Hyd. lines from the front loader? What was the pump used for, it looks to be original?
havvey
12-26-2003 18:49:52
 Re: ZAE - Hydraulic to be removed in reply to Rick, 12-22-2003 07:11:21
sir if you dont need the hydralics it would be easy to remove pump and cap hole as stated. i need the controle lever and steel lines going back to rear (if this system has the tank under the gas tank)
Brad Konrath
12-26-2003 14:57:58
If you do take off the pump, let me know as I could use one if you wanted to sell it.
Thanks.
Brad Austin
12-30-2003 12:05:07
 Re: Re: ZAE - Hydraulic to be removed in reply to Brad Konrath, 12-26-2003 14:57:58
Brad,
I have the pump off of my sons ZAU if you are interested. E-mail me and I'll send you my phone number.
Thanks,
Brad Austin
John G
12-22-2003 16:51:11
If you are going to remove the hyd system, take the pump off too. All you have to have is a steel plate to cover the hole with a gasket. There is no oil pressure there, just splash. If you run the pump dry, it won't take too long and the thing will lock up the engine or take out some of the cam drive gears.
G. L. Perry
12-22-2003 10:24:55
Is this gonna be for sale? I'm not sure what a loader for older ones looks like. Where you at if for sale? Can't those lines be left on and go back to controls or such? Doesn't loader have any quick dis-connect lines so you can take off w/out removing all parts? Wonder if you can have a Loop hose to go in and out of pump? Any shop could make if they had the right ends for it. On the tele-flo, you just put plugs in the control box section under seat. I'm not sure what older units had/have for hydraulics.
