Minneapolis Moline Tractors Discussion Forum
Trans oil in M670 Super?
Eddy.Showers
12-15-2003 18:57:08
I have a thread pipe on the right hand side of tractor seat towars the back of tractor. Is this where you add rear end and hdy fluid? and if so what weight or type should I use? Many thanks for reading and if you can help ,
kevin bauza
12-25-2003 13:31:42
 Re: Trans oil in M670 Super? in reply to Eddy.Showers, 12-15-2003 18:57:08
I don't ever like using anything than what was recommended by manufacturer. My local AGCO/WHITE/OLIVER dealer has a current spec. chart for older tractors and the 80-90 is still in vogue with them. REMEMBER---The newer transmissions use a lube pump which forces oil thru passageways in the shafts and gears. The older trannys just sling it around (M670). Thus I feel the need to stay with the heavier oil. The G900's are pressure trannys and use the lighter oils. I have seen many instances were this is exactly backwards (G1350's and 900's running heavy oil by mistake)
G. L. Perry
12-16-2003 01:11:06
NO No! Hydraulic fluid for tele-flo YES, it goes in that tube, which should have a cap and dipstick on it. Don't overfill.
The gear case oil goes in the big plug on cover near shifter. It's big, about 1-1/2" diameter, big hex. I used a bolt head and pipe-wrench to turn it. IF you have the tin cover over that center section, maybe it's covering it?? IT's just behind the shifter in the corner of aluminum cover. The fill level is a small pipe plug near the right side brake pedals, about 1/3rd way down case. Need to remove it and when oil runs out, it's enough! You should get an owner's manual, it's all in there and more! The gear case takes 89-90 wt oil. BUT, I was told with the Torque if you have, it will shift easier, smooother with the new Universal Hydraulic/gear oil like in new tractors. I got mine at TSC. Takes about 15 gals in gear case if you drain it. Shouldn't mix oil types. This oil CAN also be used in tele-flo hydrailics, but again, don't mix with other stuff in there. There is a drain plug in tee at bottom of fill tube there and it takes quite a bit to fill also, think 2gals or so?? The plug for gear case to drain is on bottom of case, near back, may have to push draw bar aside and clean to see it. Big hex plug again. Good Luck, buy the manuals!
