Minneapolis Moline Tractors Discussion Forum
Moline GVI
Rob
12-14-2003 20:50:39
I would like to know what you have to do to make the big diesel (blow a little black coal) on the pulling sled.Any info appreciated
Puller
12-20-2003 19:07:13
 Re: Moline GVI in reply to Rob, 12-14-2003 20:50:39
Put a blower to her and she'll throw smoke outta the stack like a Super Stock...a little propane injection might not hurt either
Trever Maas
12-19-2003 12:12:57
Turn the fuel delivery on the pump up to the high end of specs. I know on the U302, M5, 504, M602, M604, M670, G705, G900, G950, G955, G1000, G1350 and so on they had the Roosa-Master/Standadyne DB pump. I've went through one of those. On those all you have to do is take the top governor control cover off, take an hex key wrench, and turn the leaf spring screw in clockwise to increase fuel. On the G1000 tractors they want 94-99cc of fuel at 900 rpm per 1000 strokes. Each flat on the screw is worth 5cc of fuel so turn accordingly. Also you can increase the roller to roller dimension on the DB's to adjust max fuel. Not sure where the adjustment is on the Bosch PSB pump like you have. I know the Bosch 100 has an excess fuel screw and a cam nose adjustment. You adjust the cam nose down for more fuel. I think the Model 100 and the PSB are pretty similar, both sleeve metering pumps. Take it for what it's worth. The only major way to increase fuel for more power is to use bigger plungers or different injectors. Also bigger delivery valves help, but that's more for smoke than power. :-)
Hope that helps some.
Trever
Rob
12-19-2003 15:43:05
 Re: Re: Moline GVI in reply to Trever Maas, 12-19-2003 12:12:57
Trevor,I have an american bosch pump
Mopower
12-16-2003 09:51:14
Set a G1000 top end on it and go to town. Plenty of HP.
E J
12-15-2003 08:03:50
Get the wrench out and open up the fuel setting make it look like a freight train.
ntmcj
12-14-2003 22:50:25
Run some high sulfur diesel (fuel oil) maybe?
Rob
12-15-2003 12:48:59
 Re: Re: Moline GVI in reply to ntmcj, 12-14-2003 22:50:25
Or maybe I could just dump some used motor oil in the fuel tank.Duh!I dont think I want to dump some kind of infurior fuel in it to make horsepower
ntmcj
12-15-2003 22:17:07
 Re: Re: Re: Moline GVI in reply to Rob, 12-15-2003 12:48:59
DUH!! Unless your GVI was made in the last 10 years or so,(if I remember correctly, GVI's haven't been made since the 1960's) it ran on high sulfur fuel when it was new. Most diesel today is low sulfur for emissions regulations. If you want it to blow smoke thru the exhaust, high sulfur fuel is one way to do it.
