Minneapolis Moline Tractors Discussion Forum
Minn Moline B F
Keith Ault
12-14-2003 20:07:06
need help in solving problem.Transmission shift lever rotates in socket on top of transmission.Repair manuel shows some type of clip or seal that was originaly used to keep shift lever from doing this, has anyone else had this problem and how did you fix it
Larry from MD
12-15-2003 15:26:26
 Re: Minn Moline B F in reply to Keith Ault, 12-14-2003 20:07:06
The pieces that hold the lever in don't keep it from rotating.Normally there is a pin that sticks into a slot on the lever.The pins do wear and fall out sometimes.The rounded style pins usualy let more rotation happen.I have removed the lever and welded up the parts and grind or file down till they fit good again.The pins falling out is why you see some tractors with a hose clamp around there aparentlly not doing anything.
