Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline Shear Bolts
Jim
12-13-2003 23:09:45
I am in need of shear bolts for my MM baler.
The manual warns to use only square head shear bolts. I can't figure the square head part out as the bolt holes are not special.
Can anyone shed some light on this?
Also, are the regular MM shear bolts available anywhere?
Thanks,
Jim
galenv
12-14-2003 15:54:00
 Re: Minneapolis Moline Shear Bolts in reply to Jim, 12-13-2003 23:09:45
All the balers we've had specified grade 2 shear bolts. If your holes are ovaled or wallowed out any its hard to keep a grade2 in there when you start up. If you run grade 5 bolts be on your toes real easy to brake needles
John G
12-14-2003 15:35:26
As a general rule, the square head bolts are very soft material. That may be the reason for using square head bolts. My MF12 baler uses a very soft shear bolt also.
