Minneapolis Moline Tractors Discussion Forum
M5 no spark
Lamont
12-02-2003 12:00:17
Cannot get any spark when trying to start. It is a negative ground. There is voltage to to the positive terminal on the coil when ignition turned on and a pulsating voltage to the negative terminal on the coil when cranking but still no spark coming out of the tower on the coil.
The coil heats up. A mechanic told me that the coil was faulty so I bought a new one but acts the same. I have reconnected the points and condenser in the distributor and the coil wire in case there was a problem there.
Has to be something simple -- started easily and ran well last week.
Starting to snow --- really hope someone can help me. Thanks
Lamont
12-03-2003 15:45:13
 Re: M5 no spark in reply to Lamont, 12-02-2003 12:00:17
Thanks, Kelvin and Old, I found the problem -- the hot wire from the switch to coil was shorting out somewhere so I wired directly to the battery and the problem was solved.
Kelvin
12-02-2003 18:44:44
Is the hot wire from the switch going to the coil +? Its probably positive ground, but this will make a difference in how much voltage is available in the secondary circuit.
The other idea is to take an Ohmmeter and check for a ground where the insulator goes into the distribuitor.
3rd idea: Is the rub block worn off the moveable point in the point set? When the rivets get too close to the cam it'll short.
old
12-02-2003 17:39:36
It almost has to be your points or condenser if the coil is getting hot it sounds like the points are not opening as they should or are shorted I'd try a new set of points/condenser
