Minneapolis Moline Tractors Discussion Forum
carburator for ztu
j f g
11-30-2003 17:54:55
i need to know the gas level in carb bowl. and needle vaqlve adjustments for a marvel schoebler model tr carb. it has a tag with stampings: trx-12 443, pleeeee eze! after complete restorationi can't get it started because of dry carb or overflow, even with slight float adjustment. thank you.
AZ Jack
12-01-2003 19:02:18
 Re: carburator for ztu in reply to j f g, 11-30-2003 17:54:55
Be sure that the new gasket does not interfere with the float movement up and down. Some of these kits are getting sloppy!!! Set your float level in a straight line with the bowl if you don't have any other way-should run for you providing no dirt etc in the needle valve.
Kelvin
12-01-2003 18:22:51
Call 765-963-6628, Motec Engineering. I'm pretty sure it should be about 1/4" at the closest point with gasket, but This guy will know for sure.
