Minneapolis Moline Tractors Discussion Forum
battery
Mike
11-22-2003 17:39:31
Does any body know what type or size in cranking amps the M.M. RTU takes ? It is a 6 volt.
THANK'S
BMG
11-23-2003 15:25:14
 Re: battery in reply to Mike , 11-22-2003 17:39:31
Mike,
If you want the battery to fit in the stock location under the gas tank you'll need a low profile 6V. I believe the modern size is a 19L. If you can't find this ask for a 6V battery for an old Volkswagen. The group 1 is too tall and will short out against the gas tank (not good).
Brian
george s
11-23-2003 14:16:54
I'm not sure about the "R", but the 6 volt battery used in the "U" was a group 1. Sears has this in their "Vintage" listings. My guess is that you can find this in most battery manufacture's cattalogs.
