Minneapolis Moline Tractors Discussion Forum
Building UTS Puller Motor
Digger Dave
11-20-2003 11:11:00
Hey, I'm looking for ideas on building my UTS motor for pulling. I will pull farm stock, stock rpm, hopefully 5500, 6000, and 6500 pound class. No strokers. Looking for parts that swap versus high dollar pistons and such. Thanks, Digger
Rick
11-21-2003 20:02:13
 Re: Building UTS Puller Motor in reply to Digger Dave, 11-20-2003 11:11:00
Put a 2 cylinder JD G motor on it and you got it.
Mopower
11-21-2003 10:00:36
Hi there. A set of M5 blocks would bump your size and compression significantly, but basically an M&W kit. Bored M5 blocks would be 350 cubes and good compression with no stroking. Maybe 65-70 hp with good manifolds. Unstoppable in 1st gear I would think. Just watch your piston height.
razorback
11-21-2003 04:49:38
are you same digger dave lives ark.
Digger Dave
11-21-2003 08:01:45
 Re: Re: Building UTS Puller Motor in reply to razorback, 11-21-2003 04:49:38
No sir, Wisconsin. Also didn't mention 1st gear only.
minnie ub
11-23-2003 17:09:21
 Re: Re: Re: Building UTS Puller Motor in reply to Digger Dave, 11-21-2003 08:01:45
our ub goes from 5 mph in 1st to 8mph in 2nd we've done a little tweaking. if you don't stroke with at least a g crank your probably limited to a first gear tractor. the m5 blocks and pistons or move up to welters [4.81] is a good way to go.
Andy
11-20-2003 17:06:03
Put a set of 4213, or 4206 heads with a LP manifold set. 55-60 hp
Family Tradition
11-22-2003 19:34:39
 Re: Re: Building UTS Puller Motor in reply to Andy, 11-20-2003 17:06:03
put a G crank and M5 jugs bored to 4.81 and custom pistons from Welter's(piston will run you about 100 bucks per cylinder) run a set of 4206 heads, be around 85-90 hp if you get the compression up
