Minneapolis Moline Tractors Discussion Forum
Fiberglass radiator for GB
CS
11-18-2003 18:33:39
I am considering going with a fiberglass radiator on my GB. Any of you guys done this to reduce weight up front? I am running a 605 engine and its very heavy up front. I was told that you only get the top and the bottom and I would have to find a automotive radiator and run a electric fan. Anyone know what kind of radiator will work? . Any suggestions will be greatly appriceated. Thanks Chris
PS, also who sells the aluminum oil pans and how do you get intouch with them.
48 UTU
11-19-2003 13:22:38
 Re: Fiberglass radiator for GB in reply to CS, 11-18-2003 18:33:39
Jeremy's site posting was for alum pans 217-964-2153
Dieselbear
11-18-2003 19:02:27
Send E-mail address, Can help with pan. thanks, Glenn
KB
11-19-2003 18:22:35
 Re: Re: Fiberglass radiator for GB in reply to Dieselbear, 11-18-2003 19:02:27
Does anyone make fiberglass or aluminum parts for an M5 MM?
Dieselbear
11-20-2003 13:54:36
 Re: Re: Re: Fiberglass radiator for GB in reply to KB, 11-19-2003 18:22:35
I know brad bergman will make the pans , but you may have to send him your old one first
Puller
11-21-2003 05:29:12
 Re: Re: Re: Re: Fiberglass radiator for GB in reply to Dieselbear, 11-20-2003 13:54:36
Call Dan at 920 863 5121 for aluminum pans. He has all the materials cut out for MM 4 cyl. and 6 cyl engines in his shop now, was just there this week. Puller
Dieselbear
11-21-2003 14:34:41
 Re: Re: Re: Re: Re: Fiberglass radiator for GB in reply to Puller, 11-21-2003 05:29:12
Are Dan's aluminum pans cut and welded peices? and would you know the weight , thanks, Glenn
48 UTU
11-21-2003 07:18:07
Brad Bergman has the 6 cyl pans laying ready. Saw a couple of them, they are exact replicas, nothing fabricated (cast aluminum). I'd say one of these two guys can get you something.
