Minneapolis Moline Tractors Discussion Forum
4 star vs 4 star super
Rusty
11-11-2003 19:21:09
What is the main differance between the 4 star and the 4 star super? Will it say something in the serial #if it is a super? Have serial # 16600119 on the tractor we bought!
mmguy
11-15-2003 07:09:37
 Re: 4 star vs 4 star super in reply to Rusty, 11-11-2003 19:21:09
I have an original 4 star,1960,16601137,factory lpg. It has all of the criteria of a super but does not say it anywhere. It has not been repainted & has the original tires on it yet. According to the owners manual,supers had headlites in the grille + on M5 style fenders, a combination tail & flood on left fender {non-supers had clams w/small tailite},fuel gage,speedo & cig.lighter,600-16 fronts instead of 550-16, deluxe seat w/tension control.
JED
11-14-2003 12:59:21
my dad has a4star with slide out wheels, clamshell fenders,and a fancy steering wheel ill contact him see if he has any ideas
BMG
11-12-2003 16:25:23
Rusty,
I've got 4 Star Super w/ serial # 16600109 here in Michigan. Where are you located? Curious where a tractor only 10 numbers different ended up.
I believe only the 4 Star Supers had the deluxe dash gages with Speedometer.
Brian
Rusty
11-12-2003 17:25:17
 Re: Re: 4 star vs 4 star super in reply to BMG, 11-12-2003 16:25:23
BMG, It's great to here of all the 4 star supers out there! I wonder how many of the series where supers? I'm located in northeast Iowa.
BMG
11-13-2003 14:10:24
 Re: Re: Re: 4 star vs 4 star super in reply to Rusty, 11-12-2003 17:25:17
Rusty,
I was just in your neck of the woods this weekend. Dubuque/Dyersville to be exact. It's pretty much unknown how many were supers. I'm assuming yours is a super too?
Brian
Rusty
11-12-2003 15:55:07
Thanks alot guys! This is exactly what I was looking for! Thanks again!!!
JK
11-12-2003 05:47:14
The 3 things I always thought differentiated between the 4 Star and the 4 Star Super are:
1. fancy steering wheel with the medallion in the center
2. Stainless strip and wing-like hood ornament
3. Crown fenders similar to an M5
However when I look in the parts manual, I can only find that the crown fenders are specifically called for on the Super. The strip and ornament appear to be called for on both the 4 Star and the Super. I can't find the fancy steering wheel and medallion called for anywhere. Unlike the later models (Jet Star 3, U302 & M670), I think the 4 Star Supers were intermingled with the 4 Stars, rather than being the later models.
John
Mike (WA)
11-14-2003 12:14:38
 Re: Re: 4 star vs 4 star super in reply to JK, 11-12-2003 05:47:14
Not even sure of the M5 fenders- I have a super with all the other features (also the deluxe seat), but has clamshell fenders.
John G
11-14-2003 13:07:32
 Re: Re: Re: 4 star vs 4 star super in reply to Mike (WA), 11-14-2003 12:14:38
The parts book lists the M5 fenders for the super. Yours may have been changed, I'd change mine if I HAD to use it to rake hay. The fenders are in the way & can't see the tire and rake when making a tight turn. The regular 4 Star could have all the options as a super, I've seen a couple with all the options and clamshell fenders. Don't know the answer to this onefor sure!!!
reddog
11-11-2003 20:08:01
your tractor is a 1959,first year of prodution of 4 star or jet star 4, 119th one built out of 2537 total. i do not believe its a super the way i read the book.
John G
11-12-2003 05:52:04
 Re: Re: 4 star vs 4 star super in reply to reddog, 11-11-2003 20:08:01
The main differences are the super came with M5 fenders, and speedometer. There may be other small differences, but these are the main ones. The super was a loaded tractor, ps, 3., pto, ampl tork, spin out wheels, all the options. At least all the ones I've seen were. Also, the serial #s do not tell if it's a super. I've got #16600075.
