Minneapolis Moline Tractors Discussion Forum
Jet Star 3, points, plugs ?
George G
11-09-2003 14:35:26
Need to know what the gap is for the points and the plugs. Also, If I pull the distributor out, so I can do the points, Is it a pain to get back in right? Has the distributor got a gear on the end of the shaft, or a straight piece that fits into a slot? The tractor is either a 1968 or 1969. Thanks for any help you can give me.
Kelvin
11-10-2003 19:01:48
 Re: Jet Star 3, points, plugs ? in reply to George G, 11-09-2003 14:35:26
I can see your problem-there's about 40 bolts in the hood.
I'm pretty sure you can see all you really need to see in the distribuitor if you remove the alternator.
If you want to remove the distribuitor it should have a straight piece that fits a slot, at least my U302 dist. has one and it'll only go in one way.
Be sure to mark the housing and block so everything will be timed correctly.
I usually set my points to .020, The book may call for .022. I gap my plugs .032. Don't know what the book calls for, it may be less. Somebody else will probably have that info.
George G
11-15-2003 15:30:26
 Re: Re: Jet Star 3, points, plugs ? in reply to Kelvin, 11-10-2003 19:01:48
Thanks Kelvin. I did'nt count how many bolts were holding the hood on. But, I know they did'nt want it to fall off.
