Minneapolis Moline Tractors Discussion Forum
445 hydrualic pump
greg
11-04-2003 12:02:32
my 445 hydrulic pump has started leaking fluid. the parts man where i get some parts from does not have a break down of this. it seems to be leaking between the plate that is between the outer and inner plate (if that makes sense). are there "o" rings, or gaskets or something in there or how do i fix that.
JK
11-04-2003 13:23:19
 Re: 445 hydrualic pump in reply to greg, 11-04-2003 12:02:32
Greg,
Assuming that the pump is the original style, there is no gasket or o-ring between the 3 sections of the pump. The plates are just flat enoough to seal to one another. Maybe the bolts are loose or the center plate is cracked ( I have seen that before).
It could also be that the relief valve is not operating and causing the pressure to be too high, causing a leak. If that is the case fix it quickly. Thats what caused the cracked center section.
John
