Minneapolis Moline Tractors Discussion Forum
445 oils
gary
10-31-2003 06:34:24
does anyone know the type of oil for the transmission, differential, hydraulics and the TA in a 445, also where they are checked and filled? i have ordered an IT manual but have not got it yet and i want to change oils.
Frank (n.mi.)
10-31-2003 15:30:29
 Re: 445 oils in reply to gary, 10-31-2003 06:34:24
Trans oil is 80-90 weight gear lube. Capacity is 8 gal. in a std trans. or 10 gal for a hi-lo trans. There are two plugs on the right side of the trans. adjacent to the brake pedal. These are to see if it is low when checking trans. oil. Fill is the 3/4" size sq. plug behind the shifter. The trans has a forward and a rear section but the rear fills and overflows to fill the front section. Check both plugs to confirm both sections are full. Hydraulic filler is under the seat. The rectangular plate with four bolts comes off to fill hydraulic fluid. Fluid level should be about 1/2 inch below the plate when the hitch is down. Not sure about the differential....
