Minneapolis Moline Tractors Discussion Forum
It's getting colder out, lets heat it up a bit!
Bob (spelled ba
10-27-2003 17:49:43
Okay Minnie Mo tractor folks, which tractor is better overall, the Minneapolis U or the Massey Harris 44 and why?
Roger
10-29-2003 15:59:22
 Re: It's getting colder out, lets heat it up a bit in reply to Bob (spelled backwards), 10-27-2003 17:49:43
Since I own 6 Moline U's and only 1 MH 44, you
know which one I prefer. Now if you want to get a
real discussion going - lets compare my fathers JD
50 to ANY tractor. Having used the 44 and that
&($#)#*&$ 2 cyld. shaking bucket, I can't imagine
why anyone thinks those 2 cylds. are any good at
all. Trying to back one up to a piece of 3 pt. eq.
is almost impossible. And worse is using it to run
a post hole digger. I have driven 3 miles to get
the 44 just so I wouldn't have to use the JD 50 on
the post hole digger.
wendel
11-01-2003 03:56:40
 Re: Re: It's getting colder out, lets heat it up a in reply to Roger, 10-29-2003 15:59:22
I pull molines but use JD's.I agree with you on backing up. But would rather ride my 50 JD than a massey. Its hard to hit the right gear on a 44.Wendel
Chris
10-29-2003 06:54:26
The Moline is by far the greater tractor. Easy to work on, DEPENDABLE unlike anything Massey ever made, and GOOD LOOKING!
deadeye
10-29-2003 06:08:35
Silly question on an MM forum..... deadeye
Mopower
10-28-2003 10:15:05
I traded my UTS for a nice 44. The 44 and 33 tranny were the same and no where near the heft of a U. The motor in a U was bigger, stronger, and lugged better. Also easier to get on and off. The 44 is cice to drive and runs nice, but it is more between a MM Z and U size. By the way, I sold my 44. Looking for the next MM to play with. Grandpa has a 44-6. Sounds like an Oliver, but nowhere near the power of a 44 4 cyl or a MM U.
RJ
10-27-2003 21:20:22
The MM U of course, because it was made in the United States of America! and MM power is hard to beat.
JW
10-27-2003 19:57:48
U, its easier to get on and off of but sits a little low
