Minneapolis Moline Tractors Discussion Forum
Steering shaft universal joint
Mike
10-27-2003 08:41:13
Does any body know if you can buy a replacement Steering shaft universal joint for a 1951 RTU M.M.,as mine is a little sloppy ? Not sure of the part number as the service book does not give the number. THANK's
morgan heaton
10-29-2003 10:28:27
 Re: Steering shaft universal joint in reply to Mike , 10-27-2003 08:41:13
I just bought one for my moline GB, I used a yoke and joint for a pto shaft( like dump truck pto). I went downtown to my local napa store and picked one up, all together it was 20bucks, I didnt think that was to bad and it looks just about like the orignal. also its greaseable and next time I can replace the u-joint. Morgan Heaton
Phil
10-30-2003 18:17:55
 Re: Re: Steering shaft universal joint in reply to morgan heaton, 10-29-2003 10:28:27
You did not happen to keep the part nos's off the reciept or still have the numbers you got from the NAPA dealer would you? I need a new joint for my ZAU.
Phil
morgan heaton
10-30-2003 19:12:46
 Re: Re: Re: Steering shaft universal joint in reply to Phil, 10-30-2003 18:17:55
I still have the boxes, I will look at the part number and get back to you Phil.
Morgan
morgan
11-02-2003 18:24:02
 Re: Re: Re: Re: Steering shaft universal joint in reply to morgan heaton, 10-30-2003 19:12:46
sorry about the delay, the NAPA numbers for the yokes are 1522 and the cross is 338. That is for the ones with a keyway and a 5/16 thead hole for a set screw. They make some that take a roll pin. I used a full thread 5/16 bolt that went through the hole in the shaft. It looks good and the hole in the shaft is 5/16 so there is no play.
Morgan
Kelvin
10-27-2003 18:15:26
There may be some NOS joints out there, but
what you can do is get 2 6N size yokes with 1" bore and a cross to fit them and you're back in business. You may have to drill the roll pin hole through them, though.
R. Marg
10-27-2003 09:51:06
not sure if you can but send me an e-mail and I'll give you a phone number for a place that may have them
mike
10-27-2003 12:30:01
 Re: Re: Steering shaft universal joint in reply to R. Marg, 10-27-2003 09:51:06
Can't send one to you no email ,you have it blocked.
R. Marg
10-27-2003 13:28:34
 Re: Re: Re: Steering shaft universal joint in reply to mike, 10-27-2003 12:30:01
its [email protected] sorry about that
