Minneapolis Moline Tractors Discussion Forum
'51 uts lp gas
wayne
10-27-2003 06:08:45
my vapor valve is leaking really bad, is there a repair kit or replacement valves available. need gloves and guts to use it the way it is,
STEVE
10-27-2003 20:52:39
 Re: '51 uts lp gas in reply to wayne, 10-27-2003 06:08:45
SORRY I DIDN'T READ VERY WELL. SEE YOUR LP DEALER FOR THE VAPOR VALVE REPAIR OR REPLACEMENT
IF THEY CANT HELP TRY THE PARTS SOURCES ON THE MM
WEBSITE THE PART IS CALLED: VALVE -HAND CONTROL
PART NO# (IN THE OLD BOOK)UT728.
TRY WELTERS FARM SUPPLY, LESTER WENZEL
moline
10-27-2003 20:00:34
I get new vapor and liquid valves from my propane supplier.They are fairly inexpensive.He just needs the pipe size to the tank and line type and size to filter.I think(sometimes dangerous)that it is 3/4 pipe in the tank and 3/8 flare line to the filter,but please doublecheck me.
Steve
10-27-2003 14:33:54
IF I'M NOT MISTAKEN THE UT USES THE FOLLOWING:
(YOU WILL NEED TO DOUBLE CHECK YOUR TRACTOR)
#8059 (ENSIGN) MODEL R REGULATOR
#8628 (ENSIGN) GAS ECONOMIZER
I WOULD GET THE KIT FOR BOTH & A NEW LP FILTER.
ONLY ONE PLACE FOR KITS THAT I KNOW OF!!
EVERHART 2 WAY LP GAS
ROUTE 1 BOX 169
LONE WOLF, OKLAHOMA 73655
405-846-5633 ASK FOR HERMAN
CARB REPAIR KITS ????? ???
ACEd
10-28-2003 10:35:14
 Re: Re: '51 uts lp gas in reply to Steve , 10-27-2003 14:33:54
Good info on Ensign repair kit, but area code changed now 580 846-5633
