Minneapolis Moline Tractors Discussion Forum
MM 585 diesel h.p.
Ethan
10-19-2003 17:59:13
I'm curious how much h.p. a 585 was availiable with and how much one could "tweak" out of it. Big motor, big potential? I've seen some good pullers.
G 1355 Guy
10-20-2003 05:34:15
 Re: MM 585 diesel h.p. in reply to Ethan, 10-19-2003 17:59:13
Turn it up and you will blow it up. Problem comes with not getting enough oil to the mains. Trust me, I have experience with this, as mine blew sky high.
Ethan
10-20-2003 09:59:59
 Re: Re: MM 585 diesel h.p. in reply to G 1355 Guy, 10-20-2003 05:34:15
Hi there. I had not heard of this, but I did hear of oil pump problems after long field hours at higher RPMs. Thanks for the tip. I know a friend of mine that built one for pulling and it really cranks, but I think it took some significant tweaking to keep it going good. Curious to hear what folks have done. How many h.p. did yours turn before it blew?
minnie ub
10-20-2003 18:38:45
 Re: Re: Re: MM 585 diesel h.p. in reply to Ethan, 10-20-2003 09:59:59
hey ethan its dave from se ohio. we been toying with the idea of building a 585 also some good ones out there.
Ethan
10-21-2003 10:14:30
 Re: Re: Re: Re: MM 585 diesel h.p. in reply to minnie ub, 10-20-2003 18:38:45
I belive an HD800 crankshaft will fit in a 585 bumping it up to 650 or so. Sounds like an expensive project, but I'd love to see it. Maybe in a GBD with the right pieces. There is a puller called Vista Cruiser running a 585. It really cranks. (Henderson motor)
minnie ub
10-22-2003 13:16:50
 Re: Re: Re: Re: Re: MM 585 diesel h.p. in reply to Ethan, 10-21-2003 10:14:30
we're thinking about one in a g1000. not to change subject but you don't have a set of 15.5 deep treads around 40% do you.
ol George
10-22-2003 19:16:56
 Re: Re: Re: Re: Re: Re: MM 585 diesel h.p. in reply to minnie ub, 10-22-2003 13:16:50
Don't know which class you are interested in but I have one converted to alky with aluminum heads if you want to go Super Stock.
