Oil to use in 1955 Moline G.B.D.
John
03-09-1999 21:55:20
I have a 1955 Moline G.B.D. with ????? hours it. I drained the blackest oil I had ever seen out of it. What weight and type of oil should I put back in ? Would it hurt to put some cheap oil in it to clean the inside ? Thank you . John
Charles
03-10-1999 20:05:00
 Re: Oil to use in 1955 Moline G.B.D. in reply to John, 03-09-1999 21:55:20
The blackest oil you will find comes out of a diesel, will stain your hands like INK. I assume your tractor holds 2.5 gals. of oil.
Chang oil and filter install 2 gal.of oil and 2 qts of AUTO TRANS FLUID let run for about 1 hour.
Then let set over night. Crank and letrun for 15min. the next day. Change oil and filter use 10-40 Shell ROUNTUNDA DIESEL OIL and install 2 qts of SLICK 50 oil treatment. You motor will be clean inside and protected for a long time, keep oil changed every 3 months.
Wayne
03-10-1999 04:41:33
The best oil is cheap! Use a Brand Name detergent oil of proper vis. for your area. Just change oil and filter more often. I do not recommend this but have heard of people draining the oil and refill with diesel fuel and turning the engine over but do not start it then drain and refill.
Chad Wink
03-10-1999 17:44:57
 Re: Re: Oil to use in 1955 Moline G.B.D. in reply to Wayne, 03-10-1999 04:41:33
I do not know MM models very well, but if a GBD id a diesel as I assume the D indicates, make sure you use regulat diesel oil.
JOE
03-14-1999 23:21:09
 Re: Re: Re: Oil to use in 1955 Moline G.B.D. in reply to Chad Wink, 03-10-1999 17:44:57
MY UNCLE HAS A GBD THAT HE USES REGULARY AND HE USES 15W40 ROTELLA T IN IT AND HIS OTHER DIESELS AND NEVER HAS ENGINE TROUBLE
mm
03-10-1999 18:12:51
The reason the GTBD or GBD didn't do well is two reasons: one they had crankshaft trouble, two the 4 cylinder 403 gas version developed surperior torque. There were many GBD converted to 504's once MM introduced the 5 Star diesel. Part from the 336 ci diesel were used to convert them to the 504 ci six.
