Minneapolis Moline Tractors Discussion Forum
1st total brake job
Tim
10-13-2003 12:35:00
I'm doing the brakes on my Jet Star this weekend and would like to know if there is anything special to pay attention to. The discs and actuators where moist when I removed them which tells me the seals are bad. Is there anything special that needs special attention when replacing that seal?
I have a new shim that goes in behind that secondary plate.
Any suggestions or recommendations would be appreciated.
Thanks,,
justin
10-14-2003 11:08:46
 Re: 1st total brake job in reply to Tim, 10-13-2003 12:35:00
I dont know if you know about this but the spacers on the bolts need to go back in the right spots. One of the spacers is different.
Curt Cooke
10-14-2003 06:31:32
I have gotten in the habit of taking all the parts to the local machine shop to have them resurfaced. I have found that too often new discs, etc. don't make me happy. When all the surfaces are flat and the discs get to make contact with 100% of the hard surfaces, the brakes work.
JK
10-13-2003 18:25:24
When replacing the brake seals, I find a plastic bottle which fits the shaft snugly. I have even heated a bottle with a hair dryer so it will strech over the splines. I have always been concerned with the cut edge of wrapped plastic cutting the edge of the seals.
John
Kelvin
10-13-2003 18:03:19
Why the new shim? I'm guessing you messed up one taking apart. Most times unless there's serious wear on the pinion shaft bearings you can re-install and be o.k. with the same shim pack that came out of each side.
The inner plate that carries the seal has a drain hole that needs to be open and aim toward the bottom when its re-installed. Its supposed to catch any seepage and drain it away from the disks. Also, you need to protect the seal from the splines on the shaft when re-installing that plate. Last time I used a portion of a 20oz. pepsi bottle. I cut off top and bottom and split the straight part, rolled it up and put it inside the seal. Then I worked the pepsi bottle sleeve/tube over the splines, slid the whole mess back beyond the splines and then pulled the pepsi bottle out.
