Minneapolis Moline Tractors Discussion Forum
Hydraulic Rockshaft
Makeminecountry
10-12-2003 20:09:33
What purpose does the hydraulic rockshaft provide? Does it work as a lift? On the MM Z models that have a PTO, will the rockshaft work as a lift for using a box blade or brush hog, in order to lower or raise the attachment as needed.
MMC
Kelvin
10-13-2003 18:12:36
 Re: Hydraulic Rockshaft in reply to Makeminecountry, 10-12-2003 20:09:33
It was originally designed to work mounted cultivators. I have a '38 ZTU with a mechanical lift that works the rockshaft. It has a full set of 2-row cultivators. It lends itself to different applications, however. Dad's '54 ZB came from the dealer set up to operate the semi-mounted mower lift from the rockshaft.
I've seen a ZAU with 3-point, but it was homemade. Also, do you really want a pto shaft spinning between your legs?
