Minneapolis Moline Tractors Discussion Forum
MM Z or R fan bearing
Dale
10-08-2003 10:33:50
Does someone sell kits or replacment bearings for the fan on a Z or R
Kelvin
10-08-2003 19:24:57
 Re: MM Z or R fan bearing in reply to Dale , 10-08-2003 10:33:50
Dale, There are several ways you can go.
You can probably call around and find a nos hub with the bushing already installed. They might also have just the bearing.
You might also call a bearing supply house and see if they have a sintered bronze bearing the same I.D., O.D.and length as the old bearing. One thing: that bearing is only supported at the ends in the hub so oil can get to it. It might be a challenge to press it straight through the hub and into the bore on the opposite side.
One idea I played with was to bore the old bushing-its 1" O.D., I think and press a 1" long thin wall bushing into either end of it. I came up with a better hub, so I didn't try it.
dlp
10-08-2003 17:31:35
Is it a bushing or bearing? Anyway, take the old ones or measurements to a bearing house. They will be able to set you up.
