Minneapolis Moline Tractors Discussion Forum
GB Propane freezing up
david
10-05-2003 20:02:10
Hi guys i have a gb that is original lp system on it and i went to put it on the dyno today and after running 10 minutes or so the vaporizer really started frosting up and it started losing power and speed on the dyno so my friend said he thought it was getting too much fuel i dont know much about lp so i dont know does anyone have any suggestions on what i can do to stop this frosting up on the vaporizer? Thanks a lot guys!
Russ
10-08-2003 17:03:02
 Re: GB Propane freezing up in reply to david, 10-05-2003 20:02:10
GB Dyno test; If the dyno test is really desirable preheat the radiator with a radiant heater coupling with the radiator core thru
the air or a kerosene red devil at a good distance. This will supplement the system
to give adequate propane flow under cooler operating initial temperatures.
Or wait for ambient temperatures which will support the test right off the bat.
Steve
10-08-2003 11:04:42
MAKE SURE THAT YOUR RADIATOR IS FULL
Roger
10-05-2003 21:15:56
10 minutes may not be enough time for the engine to get warmed up enough to keep plenty of heat to the vaporizer to keep it thawed out. run the engine longer, then try dynoing it again
Curt Cooke
10-06-2003 06:18:06
 Re: Re: GB Propane freezing up in reply to Roger, 10-05-2003 21:15:56
Roger's right. Too much or too little fuel has nothing to do with a vaporizer freezing up. It takes considerable heat to vaporize the fuel. I have a Case 400LP that has replacement LP equipment on it; also a replacement water pump. My problem is that the waterpump, which should feed the vaporizer, isn't tapped for it. I have limited water flow through the vaporizer until the thermostat is opened. For your purposes, if the air temp. is warm enough, you could probably run the machine on vapor for your test.
