Minneapolis Moline Tractors Discussion Forum
moline hydraulic cylinder leak down
Morgan Heaton
09-29-2003 07:48:26
Just bought a 59 GB, The hydraulic remote cylinder will not hold the plow up it leaks down. I have heard that the moline system uses check valves in the remote cylinder to prevent this. Is this true? Do I have to find a moline cylinder and where? Can I put check valve in the lines to my cylinder. Please help. Thanks Morgan Heaton
cj5fred@aol
Kelvin
09-29-2003 18:13:17
 Re: moline hydraulic cylinder leak down in reply to Morgan Heaton, 09-29-2003 07:48:26
Yes, that's MM's better way. I've heard Welter's sells a check valve that you can install in your lines between the valve and cylinder so you can use a regular cylinder. 417-498-6496
Morgan Heaton
09-29-2003 16:08:07
Thanks for the post. I dont realy understand how a check valve would work, I mean the oil would have to flow back the other way when I want to go back down. Could you explain this to me? Does it take a special valve or have I overlooked something. Please help me out.
Thanks in advance
Morgan Heaton
Larry O.
09-29-2003 18:11:30
 Re: Re: moline hydraulic cylinder leak down in reply to Morgan Heaton, 09-29-2003 16:08:07
Go to-- www.surpluscenter.com Then click on hydraulic--- then scrol down to Accessory valves---- then click on Check/lock valves-- then scrol down to lock valve 1/2 port Item # I 9-1343 this will work to hold your cylinder up. It is a 2 way lock valve. It opens and closes under hydraulic presaure. Larry
Larry O.
09-29-2003 10:02:19
If you don't have a MM cylinder you can put check valves in your lines. It will work the same as if on the cylinder. Larry
Bill Becker
09-29-2003 09:35:51
Moline does use check valves in the cylinder. Repair kits are available through AGCO.
