Minneapolis Moline Tractors Discussion Forum
MM-Z
Rural Restorati
09-23-2003 18:34:47
Hey Iro How are you doing ? I went back and looked at this Z I bought and Still can not locate a serial Number Plate. I looked all around clutch lever like you suggested All I found was a number below the hand clutch on axel it is JT451D does that tell you any thing about this beast I sure APPRECIATE Your help THANK YOU Glenn V. Johnson Rural Restorations
lro
09-24-2003 04:33:57
 Re: MM-Z in reply to Rural Restorations , 09-23-2003 18:34:47
Look on the engine for a plate. This srl no. will give a date for manufactor of the engine, or an appr. date for tractor.
G.V.J. Rural Restorations
09-26-2003 04:53:47
 Re: Re: MM-Z in reply to lro, 09-24-2003 04:33:57
Hey Iro Mystery solved found where tag was!! It is totally gone looks like some one removed it. So now what Have not found anything on engine yet should have tractor home next week so will have more time to look THANKS THANKS for your HELP!! Glenn
09-25-2003 04:11:56
Hey Iro Thanks for your help I will look some more There has to be a plate or some sign where on has been. THANKS Again Glenn
