Minneapolis Moline Tractors Discussion Forum
Beginner working on ZA
Todd
09-23-2003 10:01:11
My Dad has a ZA that won't run, and I'd like to get it going for him (with him). It isn't getting any spark at the spark plugs, so inititial problem being in the distributor or before. Any help on troubleshooting?
It's a positive ground, right?
BMG
09-23-2003 14:44:18
 Re: Beginner working on ZA in reply to Todd, 09-23-2003 10:01:11
Todd,
The ZA series was 6 volt positive ground from the factory. I would check to see if you're getting power to the coil when you turn on the ignition switch. If not, install a jumper wire from the battery to the coil and see if you have spark. Check the points to be sure they are clean and not corroded. Replace them and the condensor if they look at all questionable.
Brian
Phil
09-26-2003 15:45:36
 Re: Re: Beginner working on ZA in reply to BMG, 09-23-2003 14:44:18
Be sure if you replace the points, you set the gap to .020.
Phil
