Minneapolis Moline Tractors Discussion Forum
miniapolis moline, what year and model do I have
Joel Cruce
09-14-2003 20:27:19
Can anyone identify what year and model miniapolis moline tractor that I have. I found a serial number of 114987-0185-01 and a code of 89121904. I also see what appears to be a model of 283 B 4 , but I can't find any info about this.
I am looking for the year model, horse power, and any other info you can help me with. Thanks.
BMG
09-15-2003 14:23:08
 Re: miniapolis moline, what year and model do I ha in reply to Joel Cruce, 09-14-2003 20:27:19
Joel,
The 283B4 engine was produced starting in 1953 so it could be in a U series or as Kevin stated possibly a 5 Star. I can't identify the other numbers you listed. There's a tag on the right side of the trans housing with the tractor model and serial #. If that's gone there's also a serial number tag on the motor. You probably already found it since you know the engine model is 283B4 which would be on that tag. If you post the serial number of the engine which should start with '061#####' we should be able to help you identify it.
Brian
Kevin Moschenrose
09-14-2003 21:44:33
Joel, I am not sure you have the number right or not. But what you have is the number off the engine and it is a 5-star. There will be another tag on the right side of the transmission housing right next to the brake pedals. Post that number as well and we can get a little closer for you. They only made the 5-stars three years. They are 57,58,59, a few very early in 60. I own 4 of them so I might be able to help more with them.
