Minneapolis Moline Tractors Discussion Forum
Gaskets used parts
Dave S
09-13-2003 18:00:04
I have a 51 UTS and I'm looking for an oil pan gasket & rear seal, govener to crank case gasket, carb to manifold, oil filter to crank case plus others. Also looking for complete oil filter assy. for this tractor. Thanks
keith giffin
09-15-2003 15:58:31
 Re: Gaskets used parts in reply to Dave S, 09-13-2003 18:00:04
I just picked up a carb to mainfold gasket at my local AGCO dealer. They had to order it but they can probably get all of the gaskets you are looking for.
Kelvin
09-14-2003 12:06:13
Its not been but about 5 years since I got the oil pan gasket from NAPA. They also had the rear main seal. I did have to make the pieces that go on either side of the lower seal housing, however. I sawed them out of dry Popular wood, expect them to swell when the oil hits them.
I got the oil filter gasket from Wendell Everett 740-922-3335. I have since made both the oil pan and the oil filter gasket out of gasket material for another tractor.
If you have a really friendly NAPA store, they can probably help you come up with a carb to manifold gasket too.
Kevin Moschenrose
09-13-2003 18:28:47
I have an oil filter assy.
