Minneapolis Moline Tractors Discussion Forum
Jetstar 206L pistons?
Kevin Moschenro
09-12-2003 10:32:41
What will interchange with 206L pistons? I have in mine .60 over and narled. A bad deal for a motor that was overhauled??. I plan on sleeving it since I am at the bottom of my rope and too much money it to quit now. I was looking to go back to standard or close to it. Does any one have a good used set of pistons out there? I have some MM parts to do trading with or what ever. Any and all advise is welcome. Thanks!
Kevin Moschenrose
09-13-2003 16:11:10
 Re: Jetstar 206L pistons? in reply to Kevin Moschenrose, 09-12-2003 10:32:41
Come on doesn't anybody know, or have any advise and or ones to sell?
Phil
09-14-2003 00:11:31
 Re: Re: Jetstar 206L pistons? in reply to Kevin Moschenrose, 09-13-2003 16:11:10
Kevin,
I made a post to this on the MM website.. What size overbore are you currently .060 over? If you are at 3-5/8 .060, you can bore these blocks up to 3-3/4 .060.
Welters has pistons 3-3/4 .060. Everett's in Ohio has 3-3/4 pistons available as well. If you are already at 3-3/4 .060, then all you can do is sleeve it back or find another set of blocks to work with.
If you go to 3-3/4 then you end up using a U302 head gasket instead of the stock gasket for the 206L engine.
Phil
Kelvin
09-14-2003 12:33:43
 Re: Re: Re: Jetstar 206L pistons? in reply to Phil, 09-14-2003 00:11:31
Kevin You need to decide how you want to fix it. Then look for the parts to do it with.
3-5/8 = 3.625 in decimal (standard bore for 206L.)
3.625 + .060 is 3.685
3-3/4 = 3.750 in decimal (standard bore for U302 220cu.in.)
3.750 + .060 is 3.810
The way I see it, if your pistons are 3-5/8 + .060, you can either find some worn-out smaller bore blocks and have them bored to fit your old pistons-If the wrist pins are still tight. Or
You can bore the blocks you have to 3.750 and use standard bore U302 3-3/4" pistons. There might be a rod length to consider, I don't know for sure.
I would only bore to 3-3/4" + .060 as a last resort.
Phil
09-15-2003 10:12:44
 Re: Re: Re: Re: Jetstar 206L pistons? in reply to Kelvin, 09-14-2003 12:33:43
I took my set of JetStar blocks to the machine shop today to have them looked at to see if my guy could bore them. Thankfully, he can. What he did tell me is what I had already figured. The set of blocks I have COULD be bored out to 3-3/4 .060 over. However, they would be REALLY thin on the skirts of the lower part of the blocks. There would only be about 100 thousandths. worth of material left when he got done. He also mentioned that it may not be a pretty bore when it got that thin as the harmonics of the cutter in thin material tends to set up a vibration.
If one were going to bore that big, then one would have to find a beefier set of blocks at the base. There is some difference in them as the set of blocks I bought this weekend are thicker in the skirt material.
I am just going to take this new set of blocks I have and bore them to 3-5/8 .040 oversize. They look pretty good except for some slight surface rust on them. I am going to clean them up tonight to get a better look at them.
Phil
