Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline M602
Mike Wilson
09-09-2003 00:19:36
Where can i find parts for mm M602, I have a bad leak of hyd oil where the steering shaft goes into power steering box,BAD. Is this a seal that needs to be replaced or what, the steering shaft has alot of slop going into box. Thanks Mike
Trever Maas
09-10-2003 17:58:12
 Re: Minneapolis Moline M602 in reply to Mike Wilson, 09-09-2003 00:19:36
I'm having the same problem on a M670. Out of the shaft and also on the Tel-O-Flo parts. Would this be the same principle as the M-602?
Thanks
Curt Cooke
09-10-2003 06:24:23
Kelvin is likely right on. Had same trouble with my M5. I thought the shaft was worn out and almost made the mistake of having a new one made before I spoke to some wizards who told me about those seals on the steering cylinder. Repaired that and problem was solved.
Kelvin
09-09-2003 18:25:11
I had a leak similar to that on my '62 Jetstar. Wendell Everett told me that probably the seals were gone on the steering cylinder. This spring, (about 5 years later) I finally got around to replacing those seals and sure'nuff, it seemed to stop that leak, although I haven't driven it much since.
I think what happens is the cylinder seals leak and the oil reservoir around the sector gear fills. It can only drain around the steering shaft. Actually I think the sector gear housing should only have 90 wt. oil in it.
Mike Wilson
09-24-2003 19:06:47
 Re: Re: Minneapolis Moline M602 in reply to Kelvin, 09-09-2003 18:25:11
Fixed leak around steering shaft, there was a groove cut around the shaft where an o ring goes, built the shaft back, turned in back down, put in new o ring. I put in regular hyd oil, im not sure if this is correct, someone tould me they thought i should use Ford trans fluid???? Thanks for the help. Mike
galen
09-09-2003 16:16:07
I have a frontend for a 602 or M5 that I'm parting if you need a shaft give me a holler.
Ted
09-13-2003 19:01:30
 Re: Re: Minneapolis Moline M602 in reply to galen, 09-09-2003 16:16:07
Galen, is the M5 steering housing the same as the 5 Star? I am in need of one. Also where are you located at?
