Minneapolis Moline Tractors Discussion Forum
1951 RTU Tire Size
LEC
09-08-2003 15:42:00
We are restoring a 1951 RTU that has 500.15 tires on the front-end and 36" tires on the backend. We are trying to find out what the original tire sizes were, does anyone know?With the 500.15 tires on the front-end the tractor is running nose down. Everything appears like it is original.
BMG
09-09-2003 15:22:52
 Re: 1951 RTU Tire Size in reply to LEC, 09-08-2003 15:42:00
LEC,
What size 36" rubber do you have? Current 9.5-36 rubber would be correct for the 15" fronts.
Brian
Kevin Moschenrose
09-08-2003 22:18:16
There isn't anything wrong. That is the rim and tire size from the factory. They did also put 16" on the front as well. But what you are seeing is part of the "visionline" selling point of the tractor and that's the way it's suppose to look.
