Minneapolis Moline Tractors Discussion Forum
Clarification of MM model numbers
Jim
09-04-2003 20:41:53
I have a ZTU and am confused about the different models. There are many models staring with Z, U and R etc..
What is the difference between all of the Z models? All of the U models? etc..
What does ZTU stand for, I plan to restore and add decals, will a decal set for a Z be the same as the ZTU?
Thanks in advance for clearing my cloudy brain!
Trever Maas
09-05-2003 19:43:40
 Re: Clarification of MM model numbers in reply to Jim, 09-04-2003 20:41:53
Hi Jim,
Well their is a ZTU, ZTN, ZTE, ZTS, ZTI, ZTX, ZAN, ZAU, ZAU, ZAS, ZASI, ZM, ZBU, ZBE, and a ZBN.
ZT: 185 CI Engines(Approx 31 Belt HP)
ZTU: 1936-1948 Universal
ZTN: 1940-1948 Narrow Front
ZTE: 1947-1948 Extendable Front
ZTS: 1937-1947 Standard Front
ZTI: 1936-1942 Industrial
ZTX: 1943 Military
ZA: 206 CI Engine(Approx 35 Belt HP)
ZAN: 1949-1953 Narrow Front
ZAE: 1949-1953 Extendable Front
ZAU: 1949-1952 Universal
ZAS: 1949-1953 Standard Front
ZASI: 1952 Industrial
ZM: 1953-1954 Military
ZB: 206 CI Engine(Approx 37 Belt HP)
ZBU: 1953-1955 Universal
ZBE: 1953-1955 Extendable Front
ZBN: 1954-1955 Narrow Front
The for the U's their is the UT, UTS, UDLX, UTU, UTC, UTN, UTE, UTS-D, UTSD-M, UTSG, UDU-D, UBU, UBE, UBN, UBU-D, UBE-D, UBN-D, UB Special, UB Special Diesel, UTI, UTI-D, UTIL, UTIL-D, UTIL-M, and the UMIL. Basically all of them had 283 CI engines, rated from around 33 HP to around 45 HP stock, except for the UMIL which is a basically a U Industrial with a Shuttle-Shift and a GTC 340 CI engine. It is pretty rare to see one of those though.
Of course each model has their own distinctive differences.
So basically ZTU stands for a Universal Z Model Tractor. A red-nose Z shouldn't need any decals besides two 4x7" MM's for the gas tank. BTW, what year is your ZTU? I've got one also.
If you have any more questions don't hesistate to ask. I would also recommend getting some books on MM's. I could recommend at least one to you. I've got three.
Regards,
Trever
R. Thomas
07-02-2004 18:20:56
 Re: Re: Clarification of MM model numbers in reply to Trever Maas, 09-05-2003 19:43:40
Have friend you has what he says is a Model UT1 with serial number 33957-7 motor #40yl. Wants to know year and parts available. Any help would be appreciated.
Jim
09-05-2003 20:04:31
Thanks guys, that clears it up pretty much for me.
I would like a good book on MM and also an operators manual for the ZTU. Mine has what seems to be a mechanical lift, with parts missing, so I would like to get it up to be all that it can be.
My email address is [email protected] so you can tell me what booke I may need to have in my collection.
Thanks,
Jim
Kelvin
09-05-2003 19:28:25
Your model breakdown
Z-basic model designation
T-'tractor'
U-Wheel configuration:U=2 wheel tricycle front. N=1 wheel front. E=adjustable wide front axle. S=Standard tread non-adjustable wide front axle.
I=heavy duty industrial front axle.
All models except S Standard tread and I were considered Universals because they could mount cultivators as well as pull implements.
Yes, a good decal set for a Z should work for a ZTU. Most kits for Z's include the decals for ZA's. I know this is confusing, but ZA is the second version of the ZT.
You won't be needing the long hood decals, though.
Jim
09-05-2003 20:08:31
 Re: Re: Clarification of MM model numbers in reply to Kelvin, 09-05-2003 19:28:25
I appreciate your helping me out. I have been around MM products for years watching them in the neighbors fields. About time I got one!
Now I can know more about my tractor and all MM tractors in general.
I had an old MM grain drill for several years, I believe it was a R5-10 model
