Minneapolis Moline Tractors Discussion Forum
M M RT100
Norbert
09-02-2003 19:47:38
I just bought an old MM RT100.
Can't find a serial number, but found RT364A on the transmission (in front of the seat) and RE152B on the engine.
The tractor has a wide front end.
What year may it be? How much is it worse?
The tractor is not running. It is missing the electrical system (distributor, coil, wires, alternator). Where can I find those parts?
It was converted to propane. Therfore it is missing the tank. I would like to convert it back to gas. Where could I find a tank and a carburator?
The water pump needs a fix as well.
Can you help?
Norbert
John G
09-03-2003 05:56:23
 Re: M M RT100 in reply to Norbert, 09-02-2003 19:47:38
I'm in Illinois, may be able to help change over, email is best to get in touch. John
Derek R
01-22-2004 16:35:50
 Re: Re: M M RT100 in reply to John G, 09-03-2003 05:56:23
My friend and I cam across a mm with rt100 stamped in the casting on the side but would like to find out more info on the tracter itself and when it was built. stuff like that any info and web sites to visit would be greatfull.
thanks
