Minneapolis Moline Tractors Discussion Forum
G900 Alternator Upgrade Question
C.J. Fitzpatric
08-29-2003 19:57:44
Alternator on my G900 gasoline was not charging. Replaced it with one that came off a G900 diesel. The single-battery on the gasser only required a 32 amp alt whereas the dual battery system on the diesel came with a 55 amp alternator. Am I going to have a problem with a greater output alternator or will the voltage regulator protect from over charging? Can I now add better/more field work lights? Any other potential problem with this "up grade"?? Thanks for your input . . . Chuck
answer
08-29-2003 20:21:53
 Re: G900 Alternator Upgrade Question in reply to C.J. Fitzpatrick, 08-29-2003 19:57:44
CJ, The bigger alt. will recover the battery quicker than the 32 amp. Yes, you may add work lights, within reason. The bigger alt. will cut itself back quicker and not have to work as hard as the smaller one. Ineffect it has reserve. No problems.
