Minneapolis Moline Tractors Discussion Forum
Model help please !
Tyler
08-25-2003 20:43:04
I need some help, New to Molines, I need to know what this tractor is.
Model- 283 B 4
serial# 061052826
or may be 661052826 this is an L/P Tractor, wide front, PTO, Drawbar, one set of hyd outlets. Engine is stuck. Any help appreciated !
Thanks, Tyler
Kevin Moschenrose
08-25-2003 22:10:42
 Re: Model help please ! in reply to Tyler, 08-25-2003 20:43:04
What you listed is the serial number for the engine. There is another on the transmission on the right side by the brake pedal. The serial number you gave is an engine for a 1953 UB. If the steering wheel is in the middle above the gauges then that's what you have unless it has been changed out the other number is more helpful.
Tyler
08-26-2003 10:06:54
 Re: Re: Model help please ! in reply to Kevin Moschenrose, 08-25-2003 22:10:42
Ok, I found the tag, it says-
Model U
# 012115223
This is an L/P Tractor.
Year model, Model????
Thanks, Tyler
BMG
08-26-2003 14:47:17
 Re: Re: Re: Model help please ! in reply to Tyler, 08-26-2003 10:06:54
Tyler,
I think you've found a 1953 UTS but you've got one too many digits in the serial number you listed. 1953 UTS had serial number range 01210571-01213219. Double check the number. I think it might be 01211523 since UTS production stopped at 01215150.
Brian
Tyler
08-26-2003 15:03:31
 Re: Re: Re: Re: Model help please ! in reply to BMG, 08-26-2003 14:47:17
Brian, You were right, My big fingers got in the way again, it is # 01211523, under model it only has the "U", This is an LP Gas tractor,engine stuck.
Thanks, Tyler
Kelvin
08-26-2003 18:00:51
 Re: Re: Re: Re: Re: Model help please ! in reply to Tyler, 08-26-2003 15:03:31
My '54 UTS only says U on the serial number tag, too. Should have a non-adjustable wide front on yours, steering wheel set at crazy angle to reach steering gear on side of transmission case.
Hope its not too hard to free up.
