Minneapolis Moline Tractors Discussion Forum
Twin City 605
HaySam
08-22-2003 14:43:39
I have a MM 605 LP on a well with a 2 to one gear runing motor about 700 rpm. when I try to get more rpm it will pop back through the air cleaner Is it fuel or mag? Hot in Southwest Ark.
Howard H.
08-27-2003 22:02:46
 Re: Twin City 605 in reply to HaySam, 08-22-2003 14:43:39
Hi,
I've run a lot of hours on MM's out here pumping water - you might check the valves, too.
A tight (or burned) valve can cause that.
Good luck,
Howard H.
Captainhookerus
08-22-2003 20:52:45
First I would guess that your gear head gives you two turns of the pump for each turn of the engine.
Next I would guess that your old 605 is tired and using a little oil maybe two Qts in 24 hours. If you are not using LPG Natural gas motor oil you have a big bunch of ash deposits in your combustion chambers. This causes two problems, it raises the compression and also gets hot on its sharp edges and lights the fire before the spark plug does. Good solution if this is the problem is to change the oil and wind engine up with no load and run a couple of pop bottles full of water into carb. The cold water mist will crack loose ash deposits and send them flying up the exhaust pipe.
Ken
