Minneapolis Moline Tractors Discussion Forum
670 heads off?
G. L. Perry
08-16-2003 02:17:04
Have a 670, seems water in cylinder or past gasket. It appears as though I can remove one head at a time as there is a gap between pairs. If I do that and replace head gasket, will the cylinder base gasket still be OK? If my head is cracked, can it be fixed or welded? I've seem my local auto machine shop fix a JD head with some inserts he puts in holes he cuts along crack. He says it draws them together, would think it would push crack apart?? He was doing right near an exhaust valve even! Heads are hard to find and expensive I guess. These are off a 602 or maybe an M-5 engine. Are they easier to find than the orig 670 ones?
Andy
08-16-2003 06:37:16
 Re: 670 heads off? in reply to G. L. Perry, 08-16-2003 02:17:04
GL, it's no problem to take one head off. the block gasket should be fine. I would take the other head off as long as you have it this far. You can check the valves. The older style, (round port) heads are easier to find. If your machine shop says the head you have is irrepairable leave a post in classifieds and you should come up with something. Andy
