Minneapolis Moline Tractors Discussion Forum
urethane paint
Darrell
08-15-2003 19:57:21
I am having trouble getting the primer covered on my ZB with DuPont Ful-Thane paint. I have five coats on and I can still see the primer. I was told that it takes several coats but this is nuts. I painted the wheels cherry red with two coats and they look great. Is this a problem with all praire gold paints or just this brand? I used an epoxy primer that is green tinted, should I have used red? Thanks.
Tom Peterson
08-18-2003 05:44:20
 Re: urethane paint in reply to Darrell, 08-15-2003 19:57:21
In the future you might consider using a white primer. I use the urethane based PPG DP48LF and have never had a problem covering it with the prairie gold.
Kelvin
08-17-2003 12:38:21
All I know is that it takes a lot of coats to cover Rustoleum brown with MM paint too. It would probably work best to apply a light grey primer, then the Prairie Gold.
Just an observation about yellow paint: Your paint was probably mixed in a more or less clear base. The only color you have is whatever was squirted in there before it was mixed up. I ran into the same problem with a yellow color I was painting the trim of a building with this summer.
The Yellow required 2 coats,(And three wouldn't have hurt) but a basic brown mixed in the same stuff only required one.
