Minneapolis Moline Tractors Discussion Forum
getting a 602 started
Milan Davig
08-13-2003 18:37:41
My neighbor was asked to get a 602 MM started that had been sitting for about 3 years. We replaced points, condenser, rotor and dist. cap. We seem to be getting weak fire at the spark plugs. We are unable to get it started. Any suggestions? Thanks.
Milan
John G
08-13-2003 18:58:57
 Re: getting a 602 started in reply to Milan Davig, 08-13-2003 18:37:41
Gas or LP? Weak spark?, is the coil good enough? Is it getting fuel? How's the compression? Maybe low voltage if you are "jumping" a low battery. I'd try the low voltage 1st, fuel 2nd or 1st. If you think it's a voltage problem and have a good battery, try pulling it in 4th, high side of TA. 3 years, could be bad gasoline.
John G
08-14-2003 17:59:28
 Re: Re: getting a 602 started in reply to John G, 08-13-2003 18:58:57
Thanks for the suggestions. We pulled the carb and drained the tank. We hope that's enough.
John G
08-13-2003 18:56:28
