Minneapolis Moline Tractors Discussion Forum
RT piston bore
Kevin
08-13-2003 17:04:12
I am restoring a 1950 RTE. I have found pistons with a 60 over bore. Would this much bore cause any problems such as overheating? Thanks.
dlp
08-15-2003 18:13:58
 Re: RT piston bore in reply to Kevin, 08-13-2003 17:04:12
Well, my ZTU is overbored .180" & no problems whatsoever. My cylinders were rusted so bad that .060' would not clean them up. I believe they were .060 Jet Star pistons. I bought them from a MM tractor outfit in Missouri.
John G
08-13-2003 18:49:55
I've got a couple of engines with the 60 overbore, 1 with RE blocks and the other with 10A blocks, the problem is boring thru the block into the water passage, not with overheating because of the overbore.
galen
08-13-2003 20:16:59
 Re: Re: RT piston bore in reply to John G, 08-13-2003 18:49:55
what size overbores are out there for the R and Z. I just took my wife's R apart, it was stuck doesn't look real good. Need to have an idea if I can salvage 1 set of jugs the other set is cracked
Kelvin
08-15-2003 19:23:02
 Re: Re: Re: RT piston bore in reply to galen, 08-13-2003 20:16:59
Are they cracked in the cylinders? A lot of hairline cracks in the outside can be repaired. I've even got an R thats been repaired inside the rocker arm area.
galen
08-16-2003 11:34:55
 Re: Re: Re: Re: RT piston bore in reply to Kelvin, 08-15-2003 19:23:02
I'm not sure where it's cracked at. I'll have to get the pistons out and clean it up to find out
