Minneapolis Moline Tractors Discussion Forum
Tractor Pulling MMs
Tyler Neff
08-10-2003 14:31:22
Ive been pulling tractor for about ten years mostly green ones.(currantly a JD 70).It does a real good job but Ive always wanted to build a moline . I pull the 7500,8500,9500# classes what kind of power do I need,and do I need four or six cylinders? Also how big should I go with it?My 70 is 750ci but I dont think i need that much in a moline to make it run like my Deere.
DAVID
08-16-2003 10:11:35
 Re: Tractor Pulling MMs in reply to Tyler Neff, 08-10-2003 14:31:22
I PULL A 1950 UTS 6500-7500 USUALLY COME 1ST TO 3RD GENERALY OPERATOR ERROR WHEN i DONT DO WELL THE CLASS I PULL WOULD SIMULAR TO NATPA DIV 2 LOW GEAR ONLY WITH 18.4X38 TIRES NO CUT I ALSO PULL STOCK 1951 ZAS AT 4500LBS HAVE BEEN POINTS CHAMP LAST 2 YEARS . YES MM DO PULL WELL HAVE FUM
David
08-15-2003 05:56:12
What are some of the rules you have to go by? This would help with an answer. If you can, go with a 6 cylinder. Irrigation motors parts are not that hard to find to put into a 6 cylinder motor. Four cylinder tractor can be made to run in the classes you mentioned with not to much work to be able to run with the JD. We have a 618 cid. UB that runs real well in classes from 5500 up to 8500 (not many 9500 antique classes around here). It usually has no problem with the two cylinder John Deere unless a driver error occurs.
john
08-12-2003 18:38:52
My stock GVI LP pulls a very reg 3rd in 6500 and 7500
dave
08-11-2003 19:21:54
we just built a ub with 500cubes and it holds its own with with jd in the 750 range. we wanted a reliable motor we weren't working on all the time. its been down the track about a dozen times with a 2nd a 4th and 2 5thsthe other times we were mid pack because we weren't weighted right.this is open rpm and no speed limit class we pulled a couple times in a 3mph class still learning there also when the governor kicks in on a moline you need the right tires to get a bite.i know a bunch will jump on me say you got to go bigger but were happy well for now.
Mopower
08-12-2003 04:51:27
 Re: Re: Tractor Pulling MMs in reply to dave, 08-11-2003 19:21:54
In the classes with speed limits, I have found smaller tough motors do ok. I pull a UB with a very stock oddball 340 motor. It is a 4.25x6. I am consistently in the top 4 of the pack in the 2.8 mph class and somewhat respectable in the 4.5mph. However, the 340 cube motor in not quite enough for 3rd gear in 5500. With a little compression and motor work it could be there. There is a Case 400 built to 350 cubes that really rips and beats us regularly. Good luck with your 500.
Ethan
Farmall Boy
08-12-2003 15:27:32
 Re: Re: Re: Tractor Pulling MMs in reply to Mopower, 08-12-2003 04:51:27
Well sorry but i am gonna jump in on this conv... We pull two '39 M farmalls..on our 281 we found that tires were the key and regularly beat a 400 cube farmall, a 650 cube G, and 600 G with a differential in it..we are pulling 3.5 mph...our other M we lightened it up to 4500 and with 264 we pull 2nd in 4500 and 1st gear in 5000....Gears, weight placement, and tires are all key roles in pulling...horse power is nothing if not gotten to the ground
John G
08-12-2003 19:19:29
 Re: Re: Re: Re: Tractor Pulling MMs in reply to Farmall Boy, 08-12-2003 15:27:32
Bring the Ms over and let's plow and disc all spring and summer, "which my U does", and then lets go pull! I pull a stock UTS LP in the 6500# class and a Dennys Carb Shop "M" motor can't do any better than I do and it never comes out of the shed except to pull. Mine still has the 2 gaskets per valve cover that the farmer before me put on. The M does blow some impressive "O" rings out of the exhaust tho! So does the owner of the M.
Farmall Boy
08-13-2003 16:03:28
 Re: Re: Re: Re: Re: Tractor Pulling MMs in reply to John G, 08-12-2003 19:19:29
Uhhhhh hhh...my motor has nothing on it from denny's...we do use them both just to pull wagons and harrows and drags....BUT we have a MODERN farm and machinery made back in 1930 is just not eqquiped well enough for our needs....DON'T ACT LIKE YOU KNOW ME AND TRY TO PUT ME DOWN..... i do nothing but respect every body and i expect the same back to me....lets grow some maturity man FB
David
08-13-2003 17:43:11
 Re: Re: Re: Re: Re: Re: Tractor Pulling MMs in reply to Farmall Boy, 08-13-2003 16:03:28
Farmall Boy,
You need to take it easy. He never said anything about you having Denny's parts or disrespected you. You are the one blowing up at him, not him at you. Thins is NOT the tractor pulling board, we treat people with respect on the Moline board. Your the one who came here bragging about your "M" on a question about pulling a MM.
John G
08-13-2003 18:44:36
 Re: Re: Re: Re: Re: Re: Re: Tractor Pulling MMs in reply to David , 08-13-2003 17:43:11
Farmall Boy, I didn't mean to be disrespectful, just telling my story of a man here who has tooooo much money and still can't win with the "best"!!! I use mine every day and that's what "I" do. Sorry. John
Farmall Boy
08-14-2003 13:53:19
 Re: Re: Re: Re: Re: Re: Re: Re: Tractor Pulling MM in reply to John G, 08-13-2003 18:44:36
Opsssss s i thought that 1 was direct toward me sorry MY FAULT..... And to david...this is a ? about pulling thus shoulda been asked on the pulling board anyways....but it was on here so i tried to help.....but i guess my ideas aren't respected by some ppl..... .SOOOOO OO don't read um..... .OH YAH my M is nothing to brag about well the 1 i pull isn't Stock cubes,motor, head etc. tryin to compete and sharein ideas....FB
David
08-15-2003 05:49:09
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Tractor Pullin in reply to Farmall Boy, 08-14-2003 13:53:19
Farmal Boy,
The original post was asking for information about pulling Minneapolis Moline's not asking about how to pull. He asked on this board so that he would get an honest answer not every Tom, Dick, and Harry giving him advice he didn't ask for. As for you GRAND and GLORIUS M's, they might as well be stock compared to what the original poster for this topic wants to build. And yes I know how to pull and have four pulling tractors ranging from a 750 cid. GB to a small 426 cid. speed limit UB.
FB
08-15-2003 13:40:14
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Tractor Pu in reply to David , 08-15-2003 05:49:09
and i brag about my tractors????? You better check you info i was the first person on this board to reply...because no 1 else was...i am 15 and probably know less than tom,dick, or harry....I don't know alot and i don't have alot when it comes to tractor pulling...but i try to help and not try to attack people...hmmmmm ....i share what i know and thats what makes a good person...i will stand up and stop this...for whatever i have not done to you that u think i hav i am sorry
Farmall Boy
08-11-2003 09:57:49
Well apparently no1 is gonna answer...so i will give u my limited knowledge....i pull my m with a few mm's..the best setup i have seen is a gvi pulling with the 800 block...its light enought for 5500 i think????? maybe 6000...it has 300 hsp comeing out of the 800...its a real power horse..pulled in tunica's king of the hill pull and got 3rd
TYLER NEFF
08-11-2003 10:05:51
 Re: Re: Tractor Pulling MMs in reply to Farmall Boy, 08-11-2003 09:57:49
Thanx for the info. Everybody else in here must not know a thing about pullin.Maybe they should try collecting stamps.SEE YA
Ethan Berry
08-11-2003 10:50:48
 Re: Re: Re: Tractor Pulling MMs in reply to TYLER NEFF, 08-11-2003 10:05:51
To answer your question, any MM can be a good puller. I am not sure what type of class you pull in. Stock to hot-rod, they can have as much as you want. As far as 6 cyl, you are unlimited with what you can accomplish. If you would like to go smaller, a U or UB can compete from 4500-8500. All the blocks and heads are interchangeable (more or less). 5 stars are becoming increasingly popular and parts are readily availiable if you know where to look. Let me know what classes you would like to pull and I would be glad to give my 2 cents and so would many more I'm sure. Sounds like a strong JD 70 you have there. Good luck!
Ethan
Tyler Neff
08-11-2003 11:58:46
 Re: Re: Re: Re: Tractor Pulling MMs in reply to Ethan Berry, 08-11-2003 10:50:48
Ethan Im currantly pulling the 7500 8500 9500#classes so i need a pretty big engine.
Ethan Berry
08-11-2003 12:36:32
 Re: Re: Re: Re: Re: Tractor Pulling MMs in reply to Tyler Neff, 08-11-2003 11:58:46
Sounds like you need to get yourself a MM GVI. You have several engine options. You can put bigger G1000 blocks on a GVI to bump up to 504 cubes give or take a few. You can swap cranks to get a 605 or simply modify a 605 engine (uses tall blocks). The ultimate is an HD800 motor although the older 800s work well with good heads I hear. The HD800 is nearly indestructable or so I hear. More experienced pullers can give you better details. There is a 800 with factory tubo being sold at an MM auction with about two dozen other tractors and lots of parts. It is near Indianapolis. Feel free to e-mail me for details. That's my 2 cents. I do not pull any big or fast classes and my motors are good, but nothing fancy. I have a GBD, UTU, R, JetStar, and UBD. There's plenty of MM people out there that will share info as I've found out first hand. Good luck.
Ethan
Tyler Neff
08-11-2003 13:49:11
 Re: Re: Re: Re: Re: Re: Tractor Pulling MMs in reply to Ethan Berry, 08-11-2003 12:36:32
Is a massy super 95 the same as a GVI?
BMG
08-11-2003 14:32:39
 Re: Re: Re: Re: Re: Re: Re: Tractor Pulling MMs in reply to Tyler Neff, 08-11-2003 13:49:11
Tyler,
Yes, a super 95 is the same as GVI.
Brian
