Minneapolis Moline Tractors Discussion Forum
End-play
Paul Brown
08-08-2003 18:30:34
How much end-play should there be on my KTA pulley drive shaft? I think I am getting to the bottom of the "noise".
Thank you,
Kelvin
08-09-2003 19:04:58
 Re: End-play in reply to Paul Brown, 08-08-2003 18:30:34
If you're talking about the belt pulley shaft, I don't think it should have any noticeable end play.
I don't know how a KTA is made, but a U has a round cast cover on the end of the housing that the seal goes in. Behind this is a fairly large nut that preloads or controls end play of the bearings on the belt pulley shaft. It is locked in place by a sheetmetal disk that is bent out around the nut after it is set to the proper tightness. Very Important to re-bend the sheetmetal back up around the nut.
