Minneapolis Moline Tractors Discussion Forum
rti axles and housings
peter
07-27-2003 17:57:54
wanted rti axles andaxle housings in michigan or wisconsin
joe skinner
07-28-2003 15:58:21
 Re: rti axles and housings in reply to peter, 07-27-2003 17:57:54
have some in PA if you are coming into the big M-M show in the fall.
peter
07-28-2003 18:45:01
 Re: Re: rti axles and housings in reply to joe skinner , 07-28-2003 15:58:21
where and when is show how much for the parts thanks
joe skinner
07-29-2003 15:43:06
 Re: Re: Re: rti axles and housings in reply to peter, 07-28-2003 18:45:01
the show is OCT. 17,18,and 19. in McConnellsburg,PA. It's also the M-M Gold Rush convention you can call paul schmidt at 814-448-2613 or check on line at www.gsandr.com for more on the show. 100.00 bucks for the axles& hubs i pulled them off so i could use the trans section for a project tractor. joe
G. L. Perry
07-27-2003 19:44:44
Are these the same as RTU housings? I may have those if they would work. I'm in Indiana though. I do go to WI, Rock County area some times. Will be going Labor Day for Thresheree show in Edgerton. Do you have cast part numbers? These are just the housings, and axles still in them, bo brakes or hubs on them. I don't know what their worth??
M Hornick
07-27-2003 20:03:22
 Re: Re: rti axles and housings in reply to G. L. Perry, 07-27-2003 19:44:44
RTI's have a splined axle while the RTU's have a keyed axle.
Mike
